Do you have any questions?
ARIA 2 MHT CENTER
Art. No. 5947
Building instruction
Exploded drawing
Assembly
All the cabinet panels are cut from 16 mm chipboard or medium density fibreboard, butt-jointed and glued. After that, the openings for the driver and terminals are cut out and any necessary recesses cut. The chamfer on the outer baffle can be made either before the cabinet is glued together or afterwards.
Since the cabinets are relatively small, it is hardly possible to mount the crossover inside the housing. The PCB can, however, simply be wrapped in damping material and placed inside the speaker if the rear wall is not removable.
Inner damping
The damping material is loosely pushed into the cabinet. The space immediately behind the bass reflex tube must remain free.
Cabinet parts list for 1 box
Parts
Size (mm)
Quantity
Material: 16 mm chipboard or MDF
Front, rear panel
160 x 396
2
Top, bottom panel
178 x 396
2
Side panels
178 x 128
2
Crossover
Contact us
