ARIA DIPOL 1
Building instruction
Exploded drawing
Assembly
The cabinet body uses 16 mm boards. First of all, cut the holes in the boards and apply the bevels. This can be done using an electric jigsaw or hand-held circular saw set to the required angle. Once the cabinet has been completed, apply the milling work for the loudspeaker. Finally, fit the cones.
Since the cabinets are relatively small, it is hardly possible to mount the crossover inside the housing. It can, however, simply be wrapped in damping material and placed inside the speaker if the rear wall is not removable.
Inner damping
The damping material is loosely arranged in the cabinet.
Cabinet parts list for 1 box
Sketch
Crossover
Press
"In contrast, the Arias demonstrated liveliness and a fine understanding for the subtleties of the film soundtracks. They are, however, robust enough to belt it out, if the need be."
"The two dipoles interface seamlessly with the music experience and ensure that the combination achieves impressive homogeneity. Once again, it became abundantly clear that the sound characteristics of all the speakers in a surround set are of crucial importance, as demonstrated adequately by the Aria combination."
"Visaton's surround set based on the Aria speakers has unmistakably set them apart from the crowd. Despite its compact size, the set has the power and control to make a real impact."
