CT CENTER 81
Building instruction
Assembly
The construction of the CT CENTER 81 speakers is very simple, since it is only necessary to glue 6 boards together (flush). However, it is essential to work accurately since the front grille will not fit in the opening if the tolerances are too great. The grille has the following outer dimensions: 85 x 220 mm.
Inner damping
Half a mat of damping material is loosely pushed into the cabinet.
Cabinet parts list for 1 box
Parts
Size (mm)
Quantity
Material: 10 mm chipboard or MDF
Front and rear panel
85 x 220
2
Side panel
200 x 240
2
Top and bottom panel
200 x 85
2
