AL 130 A 8 OHM
13 cm (5") High-End low midrange driver similar to AL 130 8 OHM, but with black cone and modified basket.
No longer available.
Technical Data
Rated power
60 Watt
Maximum power
90 Watt
Nominal impedance Z
8 Ohm
Frequency response
fu - 8000 Hz
(fu: Lower cut-off frequency depending on cabinet)
Mean sound pressure level
87 dB (1W/1m)
Excursion limit
17 mm
Resonance frequency fs
40 Hz
Magnetic induction
0.95 Tesla
Magnetic flux
450 µ Weber
Height of front pole-plate
6 mm
Voice coil diameter
25 mm
Height of winding
18 mm
Cutout diameter
115 mm
Net weight
1 kg
D.C. resistance Rdc
5.6 Ohm
Mechanical Q factor Qms
5.19
Electrical Q factor Qes
0.39
Total Q factor Qts
0.36
Equivalent volume Vas
15.6 l
Effective piston area Sd
78.5 cm2
Dynamically moved mass Mms
8.8 g
Force factor Bxl
5.64 T m
Inductance of the voice coil L
0.85 mH
Frequency- and impedance response
Used in / Accessories:
