AL 200 DV 2x8 OHM
20 cm (8") High-End woofer with double voice-coil, stiff aluminium cone, solid aluminium die-cast basket and elastic rubber surround. Extremely low mechanical and electrical losses due to vented pole plate, vented damper and capton voice coil carrier. Fast pulse response due to light weight aluminium cone. Suitable for subwoofers, which should be connected in stereo mode.
No longer available.
Technical Data
Rated power
120 Watt
Maximum power
180 Watt
Nominal impedance Z
4 Ohm
Frequency response
fu - 9000 Hz
(fu: Lower cut-off frequency depending on cabinet)
Mean sound pressure level
88 dB (1W/1m)
Excursion limit
20 mm
Resonance frequency fs
34 Hz
Magnetic induction
1.3 Tesla
Magnetic flux
930 µ Weber
Height of front pole-plate
6 mm
Voice coil diameter
38 mm
Height of winding
20 mm
Cutout diameter
190 mm
Net weight
2.5 kg
D.C. resistance Rdc
3.2 Ohm
Mechanical Q factor Qms
4.19
Electrical Q factor Qes
0.44
Total Q factor Qts
0.40
Equivalent volume Vas
68 l
Effective piston area Sd
216 cm2
Dynamically moved mass Mms
21 g
Force factor Bxl
5.95 T m
Inductance of the voice coil L
0.3 mH
Frequency- and impedance response
Directivity pattern
Directivity pattern
Directivity pattern
Used in / Accessories:
