DAL 13 100 V
Wall/ceiling surface-mounted speakers in semi-spherical plastic housings with perforated sheet covers. Equipped with one high-quality 13 cm full-range loudspeaker. Good music sound and clear voice reproduction. The rear baffle of the loudspeaker is attached to the wall or ceiling using four screws. The transformer can be connected to the 100 volt supply using screw terminals. Next, the housing, clearly marked to prevent incorrect connection, is attached and locked in place via the bayonet mount.
  • Plastics: ABS (UL 94: HB)
Typical applications:
  • Design-Wall-mounted/ceiling-mounted speakers in 100V sound reinforcement systems in public areas, schools, hotels etc.
Attributes:
  • Moisturised cone
  • 100 V transformer
  • Includes fixing materials.
  • No longer available.
Technical Data
Frequency response
150–20000 Hz
Mean sound pressure level
91 dB (1 W/1 m)
Net weight
1.39 kg
Transformer matching
16; 8; 4 W
Sound pressure level
97 dB (1 W/1 m)@ 14110 Hz
Max. sound pressure level
103 dB (16 W/1 m)
Empfindlichkeit
94 dB (1 W/1 m)
Protective system
IP 44
Temperature range
–25 ... 70 °C
Frequency- and impedance response
Directivity pattern
Directivity pattern
Directivity pattern
