DHT 9 8 OHM
HiFi horn driver for the high-frequency range above 5000 Hz. Very good pulse response and linear frequency response due to special aluminium diaphragm. High power handling and linear impedance due to capton voice-coil carrier and aluminium voice-coil wire.
No longer available.
Technical Data
Nominal impedance Z
8 Ohm
Frequency response
3000 - 38000 Hz
Mean sound pressure level
98 dB (1W/1m)
Resonance frequency fs
5000 Hz
Magnetic induction
1.5 Tesla
Magnetic flux
150 µ Weber
Height of front pole-plate
2.5 mm
Voice coil diameter
1.6 cm
Height of winding
0.25 cm
Cutout diameter
7.4 cm
Net weight
0.37 kg
D.C. resistance Rdc
6.3 Ohm
Dynamically moved mass Mms
0.11 g
Inductance of the voice coil L
0.15 mH
Peak power handling with high pass
150 Watt (12 dB/Okt.; 7500 Hz)
Nominal power handling with high pass
100 Watt (12 dB/Okt.; 7500 Hz)
Frequency- and impedance response
Used in / Accessories:
