DK 8 P - 100 V/30 W
Re-entrant horn speaker with 100 V transformer. Light grey plastic housing. Level adjustment for 100 V model via knob, in addition 100 Ohm possible. High sound pressure and wide range of frequency response guarantee excellent voice quality. Pivoting metal frame for mounting walls, ceilings, columns etc.
No longer available.
Typical applications
Public address in factories, railway stations etc.
Outdoor sound reinforcement systems
Attributes
  • Functionally at low temperature according to EN 60068-2-1 (-40 °C; 96 h)
  • Up to the standards of the Germanischer Lloyd (requirements for electrical equipment/low temperature)
  • Plastic: ABS V0 (UL 94: V-0)
  • Metall frame: Stainless steel (1.4301)
Technical Data
Frequency response
500–5500 Hz
Mean sound pressure level
107 dB (1 W/1 m)
Opening angle (-6 dB)
37°/4000 Hz
Net weight
1.8 kg
Transformer matching
30; 20; 10; 5; 2.5 W / 100 Ohm
Sound pressure level
110 dB (1 W/1 m)@ 2644 Hz
Max. sound pressure level
122 dB (30 W/1 m)
Colour
hellgrau/light greyähnlich/similar RAL 7035
Length of cable
1.0 m
Protective system
IP 66
Temperature range
−40 ... 80 °C
Frequency- and impedance response
Directivity pattern
