DL 13/2 8 OHM
13 cm (5") HiFi-ceiling speaker with corrosion free grille, suitable for the installation in suspended ceilings of any material. Equipped with a 2-way coaxial driver. Quick snap-in mounting due to round ceiling cut-out through which the speaker with mounting ring can be installed. A quick-mounting bayonet connection provides an easy installation of the grille.
Typical applications:
  • For suspended ceilings in shops, private accomodation, bathrooms etc.
No longer available.
Technical Data
Rated power
30 W
Maximum power
50 W
Nominal impedance Z
8 Ohm
Frequency response
100–20000 Hz
Mean sound pressure level
89 dB (1 W/1 m)
Resonance frequency fs
150 Hz
Height of front pole-plate
4 mm
Voice coil diameter
25 mm
Cutout diameter
165 mm
Net weight
0.86 kg
Sound pressure level
98 dB (1 W/1 m)@ 5000 Hz
Colour
RAL 9010
Protective system
IP X3
Frequency- and impedance response
Directivity pattern
Directivity pattern
Directivity pattern
