DL 18 100 V
17 cm (6.5") ceiling speaker with corrosion free, mat white grille (RAL9010), suitable for the installation in suspended ceilings of any material. Quick snap-in mounting due to round ceiling cut-out through which the speaker with transformer and mounting ring can be installed. A push- terminal block allows a quick and easy connection to the 100-V-network including the eventually necessary level adjustment. A quick-mounting bayonet connection provides an easy installation of the grille.
DL 18 can be supplied painted in other RAL colours on request.
Speaker cabinet systems for ceilings are available for these speakers from KAISER, 58579 Schalksmühle, Germany. The KompaX cabinet is suitable for the DL 18, Art. nos. 1293-15 and 1292-00 in conjunction with the front ring Art. no. 1293-20.
Typical applications:
  • Ceiling-mounted speakers in 100 V sound reinforcement systems in public areas, schools, hotels etc.
No longer available.
Technical Data
Frequency response
70 - 20000 Hz
Mean sound pressure level
90 dB (1W/1m)
Resonance frequency fs
100 Hz
Magnetic induction
0.8 Tesla
Magnetic flux
200 µ Weber
Height of front pole-plate
3 mm
Voice coil diameter
20 mm
Height of winding
6 mm
Cutout diameter
ø 200 mm
Net weight
1.15 kg
Effective piston area Sd
129 cm2
Dynamically moved mass Mms
6.4 g
Inductance of the voice coil L
0.75 mH
Transformer matching
6; 3; 1.5 Watt
Max. sound pressure level
98 dB (6W/1m)
Frequency- and impedance response
Directivity pattern
Directivity pattern
Directivity pattern
