DL 18/1 B 100 V
17 cm (6.5") ceiling speaker with aesthetically appealing grille, suitable for the installation in suspended ceilings of any material. Easy mounting due to solid spring arms into round ceiling cut-out through which the one-piece speaker can be installed safe against ball throwing. A push terminal block allows quick and easy connection to the 100-V-network.
No longer available.
Technical Data
Frequency response
80–20000 Hz
Mean sound pressure level
91 dB (1 W/1 m)
Cutout diameter
170 mm
Net weight
0.9 kg
Transformer matching
6/3/1.5 W
Sound pressure level
96 dB (1 W/1 m) @ 4950 Hz
Max. sound pressure level
100 dB (6 W/1 m)
Empfindlichkeit
94 dB (1 W/1 m)
Temperature range
−40 ... 110 °C
Sketch
Frequency- and impedance response
Directivity pattern
Directivity pattern
Directivity pattern
