DL 18/2 8 OHM
17 cm (6.5") HiFi-ceiling speaker with corrosion free grille, suitable for the installation in suspended ceilings of any material. Equipped with a 2-way coaxial driver. Quick snap-in mounting due to round ceiling cut-out through which the speaker with mounting ring can be installed. A quick-mounting bayonet connection provides an easy installation of the grille.
DL 18/2 can be supplied painted in other RAL colours on request.
Speaker cabinet systems for ceilings are available for these speakers from KAISER, 58579 Schalksmühle, Germany. The KompaX cabinet is suitable for the DL 18/1 and DL 18/2, Art. nos. 1293-15, 1293-00, 1292-35, 1292-00, 1294-15 and 1294-00 in conjunction with the front ring Art. no. 1293-20. Fire protection housing systems (F30) are available (FlamoX).
Typical applications:
  • For fitting in hollow ceilings, for music and speech in shops, at home, hotels etc.
Attributes:
  • Moisturised cone
  • UV-resistant
  • Metal basket, non-corrodible
  • functionally at low temperature according to EN 60068-2-1 (-40 °C; 96 h)
  • up to the standards of the Germanischer Lloyd (requirements for electrical equipment / low temperature)
No longer available.
Technical Data
Rated power
50 W
Maximum power
70 W
Nominal impedance Z
8 Ohm
Frequency response
50–20000 Hz
Mean sound pressure level
90 dB (1 W/1 m)
Resonance frequency fs
90 Hz
Magnetic induction
0.95 T
Magnetic flux
310 µWb
Height of front pole-plate
4 mm
Voice coil diameter
25 mm
Cutout diameter
200 mm
Net weight
1.15 kg
D.C. resistance Rdc
6.9 Ohm
Mechanical Q factor Qms
2.68
Electrical Q factor Qes
1.68
Total Q factor Qts
1.03
Equivalent volume Vas
15 l
Effective piston area Sd
129 cm²
Dynamically moved mass Mms
7.9 g
Inductance of the voice coil L
0.75 mH
Protective system
IP X3
Temperature range
−40 ... 80 °C
Frequency- and impedance response
Directivity pattern
Directivity pattern
Directivity pattern
Used in / Accessories:
