DMR 120 4 OHM
Art. No. -
50 mm (2") HiFi fabric dome driver with square shaped front plate for the midrange band between 800 - 7000 Hz. Due to the optimised dome shape with double coating in conjunction with the highly damped surround, linear frequency response and no partial oscillations. Due to the powerful magnetic driver and the ferrofluid-cooled voice-coil high efficiency and high power handling can be guaranteed.
No longer available.
Technical Data
Nominal impedance Z
4 Ohm
Frequency response
350 - 14000 Hz
Mean sound pressure level
90 dB (1W/1m)
Resonance frequency fs
700 Hz
Magnetic induction
1.4 Tesla
Magnetic flux
880 µ Weber
Voice coil diameter
5 cm
Cutout diameter
10.5 cm
Net weight
1 kg
D.C. resistance Rdc
3.2 Ohm
Mechanical Q factor Qms
1.13
Electrical Q factor Qes
0.92
Total Q factor Qts
0.52
Effective piston area Sd
20 cm2
Dynamically moved mass Mms
2 g
Inductance of the voice coil L
0.08 mH
Peak power handling with high pass
180 Watt (12 dB/Okt.; 800 Hz)
Nominal power handling with high pass
120 Watt (12 dB/Okt.; 800 Hz)
Frequency- and impedance response
