DMR 35 8 OHM
Art. No. -
35 mm (2") HiFi fabric dome driver with square front plate for the midrange between 1200 and 10000 Hz. Linear frequency response due to the optimised double coated dome and in conjunction with a highly damped surround. High power handling due to ferrofluid cooled voice-coil.
No longer available.
Technical Data
Nominal impedance Z
8 Ohm
Frequency response
500- 12000 Hz (-8 dB)
Mean sound pressure level
88 dB (1 W/1 m)
Resonance frequency fs
800 Hz
Magnetic induction
1.1 Tesla
Magnetic flux
360 µ Weber
Voice coil diameter
3.5 cm
Cutout diameter
9.3 cm
Net weight
0.85 kg
D.C. resistance Rdc
7.3 Ohm
Mechanical Q factor Qms
1.42
Electrical Q factor Qes
2.81
Total Q factor Qts
0.95
Effective piston area Sd
10 cm2
Inductance of the voice coil L
0.08 mH
Peak power handling with high pass
120 Watt (12 dB/Okt.; 1200 Hz)
Nominal power handling with high pass
80 Watt (12 dB/Okt.; 1200 Hz)
Frequency- and impedance response
