DSM 25 R - 8 Ohm
25 mm (1") High-End titanium dome driver for the highrange above 2000 Hz. Due to the enormously strong and ultra-light titanium dome and in conjunction with a highly damped sypronyle surround, linear frequency response and no partial oscillations. Due to the enormously high magnetic flux in the ferrofluid-filled air-gap high efficiency and high power handling are possible.
No longer available.
Technical Data
Nominal impedance Z
8 Ohm
Frequency response
1000–30000 Hz
Mean sound pressure level
90 dB (1 W/1 m)
Opening angle (-6 dB)
138°/8000 Hz
Resonance frequency fs
1600 Hz
Magnetic induction
1.7 T
Magnetic flux
425 µWb
Height of front pole-plate
2.5 mm
Voice coil diameter
25 mm
Height of winding
2 mm
Cutout diameter
80 mm
Net weight
0.53 kg
D.C. resistance Rdc
5.9 Ohm
Mechanical Q factor Qms
1.83
Electrical Q factor Qes
1.87
Total Q factor Qts
0.92
Effective piston area Sd
4.9 cm²
Peak power handling with high pass
140 W (12 dB/Okt.; 2000 Hz)
Nominal power handling with high pass
80 W (12 dB/Okt.; 2000 Hz)
Frequency- and impedance response
Directivity pattern
Waterfall spectrum
