DTW 110 NG 8 OHM
Art. No. -
25 mm (1") HiFi fabric dome driver for the highrange above 2000 Hz. Due to the optimised dome and the highly damped surround, a linear frequency response without partial oscillations is guaranteed. With a high magnetic flux in the ferrofluid-filled air-gap a high efficiency and a high power handling can be realised. Especially suitable for 3-way combinations in conjunction with the fabric dome tweeter G 50 FFL.
No longer available.
Technical Data
Nominal impedance Z
8 Ohm
Frequency response
1000 - 22000 Hz
Mean sound pressure level
90 dB (1W/1m)
Resonance frequency fs
1500 Hz
Magnetic induction
1.6 Tesla
Magnetic flux
380 µ Weber
Voice coil diameter
2.5 cm
Cutout diameter
8 cm
Net weight
0.55 kg
D.C. resistance Rdc
5.6 Ohm
Mechanical Q factor Qms
1.1
Electrical Q factor Qes
2.06
Total Q factor Qts
0.71
Effective piston area Sd
5 cm2
Dynamically moved mass Mms
0.3 g
Inductance of the voice coil L
0.05 mH
Peak power handling with high pass
90 Watt (12 dB/Okt.; 2000 Hz)
Nominal power handling with high pass
60 Watt (12 dB/Okt.; 2000 Hz)
Frequency- and impedance response
Used in / Accessories:
