DTW 72 4 OHM
Art. No. -
14 mm (0.6") polycarbonate dome driver for the highrange above 4000 Hz. Balanced frequency response and excellent omnidirectional sound distribution. Due to the strong magnetic drive and the ultra-light dome in conjunction with the ferrofluid-cooled voice-coil good efficiency and high power handling.
No longer available.
Technical Data
Nominal impedance Z
4 Ohm
Frequency response
2200 - 23000 Hz
Mean sound pressure level
91 dB (1W/1m)
Resonance frequency fs
3000 Hz
Magnetic induction
1 Tesla
Magnetic flux
65 µ Weber
Voice coil diameter
1.4 cm
Cutout diameter
5 cm
Net weight
0.075 kg
D.C. resistance Rdc
3.2 Ohm
Effective piston area Sd
1.5 cm2
Dynamically moved mass Mms
0.1 g
Inductance of the voice coil L
0.1 mH
Peak power handling with high pass
110 Watt (12 dB/Okt.; 5000 Hz)
Nominal power handling with high pass
70 Watt (12 dB/Okt.; 5000 Hz)
Frequency- and impedance response
