DTW 8.12 NG 8 OHM
25 mm (1") HiFi fabric dome driver with rectangular shaped front plate for the highrange above 2000 Hz. Coated dome with linear frequency response and strong magnetic drive for high efficiency. High power handling due to ferrofluid-filled air-gap. Suitable for 2- and 3-way combinations. Due to the front plate shaping especially suitable as replacement unit for many Hifi speakers.
No longer available.
Technical Data
Nominal impedance Z
8 Ohm
Frequency response
1000 - 22000 Hz
Mean sound pressure level
90 dB (1W/1m)
Resonance frequency fs
1700 Hz
Magnetic induction
1.6 Tesla
Magnetic flux
380 µ Weber
Voice coil diameter
2.5 cm
Cutout diameter
8 cm
Net weight
0.55 kg
D.C. resistance Rdc
5.8 Ohm
Mechanical Q factor Qms
0.85
Electrical Q factor Qes
1.55
Total Q factor Qts
0.55
Effective piston area Sd
5 cm2
Dynamically moved mass Mms
0.3 g
Inductance of the voice coil L
0.05 mH
Peak power handling with high pass
90 Watt (12 dB/Okt.; 2000 Hz)
Nominal power handling with high pass
60 Watt (12 dB/Okt.; 2000 Hz)
Frequency- and impedance response
