DX 16 4 OHM
Art. No. -
16 cm (6,5") 2-way coaxial loudspeakers with polypropylene cone and polycarbonate dome tweeter. Integrated crossover (capacitor) for the tweeter. Very balanced sound. Straightforward installation in vehicles with cutouts for 16,5 cm speakers. Door and rear tray installation possible using mounting ring and grille.Mounting accessories and protective grilles are included.
No longer available.
Technical Data
Rated power
70 Watt
Maximum power
90 Watt
Nominal impedance Z
4 Ohm
Frequency response
60 - 20000 Hz (-8 dB)
Mean sound pressure level
88 dB (1 W/1 m)
Excursion limit
4 mm
Resonance frequency fs
72 Hz
Magnetic induction
1.0 Tesla
Magnetic flux
314 µ Weber
Height of front pole-plate
4 mm
Voice coil diameter
2.5 cm
Height of winding
7 mm
Cutout diameter
14 cm
Net weight
0.79 kg
D.C. resistance Rdc
3.6 Ohm
Mechanical Q factor Qms
7.35
Electrical Q factor Qes
1.03
Total Q factor Qts
0.9
Effective piston area Sd
118 cm2
Inductance of the voice coil L
0.51 mH
Frequency- and impedance response
