DX 4x6 P - 4 Ohm
Oval 2-way coax speaker with polypropylene diaphragm and European standard basket. Integrated crossover (capacitor type) for the tweeter. Simple fitting in vehicles with cut-outs for 9 x 15 cm speakers. Packed in pairs, includes fitting materials.
Typical applications:
  • Vehicles
  • Mobile homesAttributes:
  • Moisturised cone
  • Metal basket
  • Coaxial speaker
No longer available.
Technical Data
Rated power
30 W
Maximum power
50 W
Nominal impedance Z
4 Ohm
Frequency response
65–22000 Hz
Mean sound pressure level
86 dB (1 W/1 m)
Opening angle (-6 dB)
140°/4000 Hz hor.180°/4000 Hz vert.
Excursion limit
+/−1.5 mm
Resonance frequency fs
90 Hz
Magnetic induction
1 T
Magnetic flux
190 µWb
Height of front pole-plate
3 mm
Voice coil diameter
20 mm / 14 mm
Height of winding
5 mm
Cutout diameter
88 x 144 mm (oval)
Net weight
0.423 kg
Temperature range
–25 ... 70 °C
Frequency- and impedance response
Directivity pattern
Directivity pattern
