DX 6X9 4 OHM
3-way triaxial highly efficient oval speaker systems featuring polypropylene woofer and conical midrange. Powerful bass and clean-cut higher frequencies. Particularly suited to installation on the rear shelf. Easy to connect thanks to integrated crossover for midrange and tweeter.Mounting accessories and protective grilles are included.
No longer available.
Technical Data
Rated power
80 Watt
Maximum power
100 Watt
Nominal impedance Z
4 Ohm
Frequency response
40 - 20000 Hz
Mean sound pressure level
90 dB (1W/1m)
Resonance frequency fs
65 Hz
Height of front pole-plate
5 mm
Voice coil diameter
2.5 cm
Net weight
1.165 kg
D.C. resistance Rdc
3.9 Ohm
Mechanical Q factor Qms
6.06
Electrical Q factor Qes
1.13
Total Q factor Qts
0.95
Inductance of the voice coil L
0.62 mH
Frequency- and impedance response
