Do you have any questions?
FIESTA 20
Connoisseurs of crisp, powerful bass and clear higher range frequencies, coupled with excellent power-handling capabilities, will welcome the 65-litre FIESTA 20 speaker, because it was designed specifically for them.
A special crossover circuit enables the two W 200 NG 8 Ohm to work in the bass range in tandem up to around 120 Hz. After that, the output level of the lower speaker is lowered and the upper W 200 NG 8 Ohm takes over the mid-range. The pressure chamber system of the DHT 9 8 Ohmproduces high-range dynamics with amazing signal fidelity and is effectively protected against overloading by the voltage attenuator connected in series.
The special sound characteristics of this system will appeal mainly to rock music fans. This musical genre often requires high output levels and needs the right punch in the bass range. It is precisely these features, good power handling capabilities and authentic bass reproduction coupled with a moderate price that make the VISATON FIESTA 20 what it is.
Technical Data
Component parts list
Additional Content
Rated power 150 W
Maximum power 200 W
Nominal impedance Z 4 Ohm
Übertragungsbereich (-10 dB) 40 - 38000 Hz
Mittlerer Schalldruckpegel 86 dB (1 W/1 m)
Trennfrequenz 3500 Hz
Gehäuseprinzip geschlossen / closed
Net volume 65 l
Außenmaß Höhe 1020 mm
Außenmaß Breite 300 mm
Außenmaß Tiefe 300 mm
Component parts list for 1 box
Tweeter:
DHT 9 8 Ohm
1 piece
Bass-midrange driver:
W 200 NG 8 Ohm
2 pieces
Crossover:
see diagram
Terminal:
PT 57 NG
1 piece
Damping material:
4 bags
Wood screws:
4 x 20 mm
4 pieces
Countersunk screws:
3,5 x 25 mm
10 pieces
Cable:
2 x 1,5 mm2
3,3 m
Frequency- and impedance response
Accessories
Coating liquid:
LTS 50
1/2 bottle
Protective grille:
NG 8" für W 200 NG
2 pieces
Contact us
