FR 10 H 8 OHM
10 cm (4") fullrange speaker with tweeter cone and European standard basket. Simple fitting in vehicles with cut-outs for 10 cm speakers.
Typical applications:
  • Vehicles
  • Mobile homes
Attributes:
  • Moisturised cone
  • Metal basket
No longer available.
Technical Data
Rated power
20 Watt
Maximum power
30 Watt
Nominal impedance Z
8 Ohm
Frequency response
95 - 22000 Hz
Mean sound pressure level
86 dB (1W/1m)
Excursion limit
4 mm
Resonance frequency fs
120 Hz
Magnetic induction
1.1 Tesla
Magnetic flux
100 µ Weber
Height of front pole-plate
2 mm
Voice coil diameter
14 mm
Height of winding
5 mm
Cutout diameter
94 mm
Net weight
0.34 kg
D.C. resistance Rdc
7.2 Ohm
Mechanical Q factor Qms
4.78
Electrical Q factor Qes
1.73
Total Q factor Qts
1.27
Equivalent volume Vas
1.9 l
Effective piston area Sd
50 cm2
Dynamically moved mass Mms
2.8 g
Force factor Bxl
3.09 Tm
Inductance of the voice coil L
0.17 mH
Frequency- and impedance response
