FR 10 P 4 OHM
Art. No. -
10 cm (4") fullrange speaker with tweeter cone and European standard basket. Simple fitting in vehicles with cut-outs for 10 cm speakers.
No longer available.
Technical Data
Rated power
20 Watt
Maximum power
40 Watt
Nominal impedance Z
4 Ohm
Frequency response
100 - 20000 Hz (-8 dB)
Mean sound pressure level
86 dB (1 W/1 m)
Resonance frequency fs
115 Hz
Magnetic induction
0.95 Tesla
Magnetic flux
180 µ Weber
Height of front pole-plate
4 mm
Voice coil diameter
20 mm
Cutout diameter
92 mm
Net weight
0.44 kg
Frequency- and impedance response
