FR 10 WPX - 4 Ohm (white)
Saltwater resistant 10 cm (4") full-range driver with moulded plastic cone, plastic basket and grille. Absolutely corrosion-resistant and waterproof due to encased magnet and silicon-coated leads. White colour.
No longer available.
Typical applications
  • Loudspeaker for saunas
  • Outdoor PA systems
  • Loudspeaker for solariums and damp locations
  • Boats, ships and open vehicles
Attributes
  • Temperature resistant up to 120 °C
  • Suitable for outdoor applications
  • Seawater proof
  • Ball-resistant
Speaker systems for saunas
Outdoor PA systems
Technical Data
Rated power
20 W
Maximum power
30 W
Nominal impedance Z
4 Ohm
Frequency response
80–16000 Hz
Mean sound pressure level
83 dB (1 W/1 m)
Opening angle (-6 dB)
83°/4000 Hz
Resonance frequency fs
120 Hz
Height of front pole-plate
4 mm
Voice coil diameter
20 mm
Height of winding
5 mm
Cutout diameter
101 mm
Net weight
0.275 kg
Colour
weiß/white
Connections
4.8 x 0.8 mm (+)2.8 x 0.8 mm (−)
Protective system
IP 65 *)
Temperature range
−40 ... 120 °C
Frequency- and impedance response
Directivity pattern
