FR 16 P 4 OHM
Art. No. -
16 cm (5") fullrange speaker with tweeter cone and European standard basket. Simple fitting in vehicles with cut-outs for 16,5 cm speakers.Includes fitting materials
No longer available.
Technical Data
Rated power
40 Watt
Maximum power
60 Watt
Nominal impedance Z
4 Ohm
Frequency response
60 - 20000 Hz (-8 dB)
Mean sound pressure level
88 dB (1 W/1 m)
Excursion limit
4 mm
Resonance frequency fs
76 Hz
Magnetic induction
1.0 Tesla
Magnetic flux
314 µ Weber
Height of front pole-plate
4 mm
Voice coil diameter
25 mm
Height of winding
7 mm
Cutout diameter
145 mm
Net weight
0.68 kg
Frequency- and impedance response
