FR 4X6 P 4 OHM
Art. No. -
Oval fullrange speaker with tweeter cone and European standard basket. Simple fitting in vehicles with cut-outs for 9 x 15 cm speakers.
No longer available.
Technical Data
Rated power
30 Watt
Maximum power
50 Watt
Nominal impedance Z
4 Ohm
Frequency response
80 - 20000 Hz (-8 dB)
Mean sound pressure level
86 dB (1 W/1 m)
Excursion limit
3 mm
Resonance frequency fs
110 Hz
Magnetic induction
0.9 Tesla
Magnetic flux
225 µ Weber
Height of front pole-plate
4 mm
Voice coil diameter
20 mm
Height of winding
5 mm
Cutout diameter
88 x 144 mm
Net weight
0.41 kg
Frequency- and impedance response
