G 25 HE 8 OHM
Art. No. -
25 mm (1") high-end textile dome unit with compensating magnet to suppress stray magnetic field. Very well-balanced sound properties with "silky-smooth" treble. The perforated pole piece guarantees low resonance frequency, enabling an initial frequency of 1500 Hz. The powerful magnet and the voice coil, filled with low-viscosity ferrofluid, guarantee both high efficiency and good power handling capability.
No longer available.
Technical Data
Nominal impedance Z
8 Ohm
Frequency response
700 - 25000 Hz
Mean sound pressure level
90 dB (1W/1m)
Resonance frequency fs
985 Hz
Magnetic induction
1.7 Tesla
Magnetic flux
425 µ Weber
Voice coil diameter
25 mm
Cutout diameter
80 mm
Net weight
950 g
Peak power handling with high pass
140 W (12 dB/Okt.; 2000 Hz)
Nominal power handling with high pass
80 W (12 dB/Okt.; 2000 Hz)
Frequency- and impedance response
Directivity pattern
Directivity pattern
Directivity pattern
