KL 33 - 100 V (black)
33 cm spherical loudspeaker as bass reflex system. Equipped with one 17 cm bass/midrange and four midrange/highrange drivers which have a good directivity pattern at off-axis angles and therefore provide a uniform and pleasant sound quality. The KL 33 can be connected to a 100 V network or a normal amplifier (4 ohm).
No longer available.
Typical applications
Public address systems in rooms with high ceilings (shops, showrooms, supermarkets and exhibition or production halls)
Technical Data
Rated power
50 W
Maximum power
70 W
Frequency response
70–18000 Hz
Mean sound pressure level
86 dB (1 W/1 m)
Opening angle (-6 dB)
64°/4000 Hz
Net weight
4.6 kg
Transformer matching
12; 6; 3; 1.5 W/4 Ohm
Max. sound pressure level
97 dB (12 W/1 m)
Colour
RAL 9005
Length of cable
3 m
Frequency- and impedance response
Directivity pattern
