M 10 4 OHM
100 mm (4") cone midrange driver for the midrange band between 1000 and 5000 Hz. Due to the enclosed rear no separate midrange housing construction is necessary. Extremely good price/performance ratio in 3-way combinations in conjunction with cone tweeters.
No longer available.
Technical Data
Nominal impedance Z
4 Ohm
Frequency response
450–13000 Hz
Mean sound pressure level
90 dB (1 W/1 m)
Resonance frequency fs
700 Hz
Magnetic induction
0.9 T
Magnetic flux
230 µWb
Voice coil diameter
20 mm
Cutout diameter
95 mm
Net weight
0.33 kg
Peak power handling with high pass
100 W (12 dB/Okt.; 800 Hz)
Nominal power handling with high pass
80 W (12 dB/Okt.; 800 Hz)
Frequency- and impedance response
