ML 10 T - 100 V
10 cm (4") Ceiling/Wall speaker with rear cover and 100 V transformer. Good voice reproduction. Compact dimensions. Mounting guide (PDF; 410 KB)
No longer available.
Typical applications
For fitting in hollow ceilings or walls, for music and speech in shops, at home, hotels, cruise ships etc.
Technical Data
Frequency response
150–15000 Hz
Mean sound pressure level
85 dB (1 W/1 m)
Opening angle (-6 dB)
180°/4000 Hz
Voice coil diameter
20 mm
Cutout diameter
104 mm
Net weight
0.93 kg
Transformer matching
6; 3; 1.5 W
Sound pressure level
90 dB (1 W/1 m)@ 1800 Hz
Max. sound pressure level
92 dB (6 W/1 m)
Colour
RAL 9010
Temperature range
–25 ... 70 °C
Frequency- and impedance response
Directivity pattern
