ML 16 100 V
Ceiling speaker with high efficiency and good speech reproduction. Especially for installation in metal ceilings (e.g. ships). A push-terminal block allows a quick and easy connection to the 100-V-network including the eventually necessary level adjustment. After screwing the speaker to the ceiling a quick-mounting bayonet connection provides an easy installation of the grille.
Typical applications:
Installation in metal ceilingsAttributes:
  • Functionally at low temperature according to EN 60068-2-1 (-40 °C; 96 h)
  • Up to the standards of the Germanischer Lloyd (requirements for electrical equipment / low temperature)
  • Moisturised cone
  • UV-resistant
  • Metal basket
  • 100 V transformer
No longer available.
Technical Data
Nominal impedance Z
5; 10; 20 kOhm
Frequency response
100–15000 Hz
Mean sound pressure level
94 dB (1 W/1 m)
Opening angle (-6 dB)
55°/4000 Hz
Resonance frequency fs
150 Hz
Voice coil diameter
14 mm
Cutout diameter
143 mm
Net weight
1.1 kg
Transformer matching
2; 1; 0.5 W
Sound pressure level
102 dB (1 W/1 m)@ 4954 Hz
Max. sound pressure level
97 dB (2 W/1 m)
Colour
RAL 9010
Temperature range
−40 ... 110 °C
Frequency- and impedance response
Directivity pattern
