SC 4 ND 4 OHM
Magnetically shielded HiFi titanium dome tweeter for the high-frequency range above 2000 Hz. Due to the highly damped sypronyle surround the frequency response is free from partial oscillations. The ferrofluid-filled air-gap provides a high power handling. Magnetic shielding and compact dimensions thanks to the use of a neodynium magnet system. The latter allows real D`Appolito baffle designs.
No longer available.
Technical Data
Nominal impedance Z
4 Ohm
Frequency response
1000 - 22000 Hz
Mean sound pressure level
90 dB (1W/1m)
Resonance frequency fs
1350 Hz
Voice coil diameter
2.5 cm
Cutout diameter
5 cm
Net weight
0.106 kg
D.C. resistance Rdc
3.4 Ohm
Mechanical Q factor Qms
1.87
Electrical Q factor Qes
1.56
Total Q factor Qts
0.85
Effective piston area Sd
5 cm2
Inductance of the voice coil L
0.71 mH
Peak power handling with high pass
120 Watt(12 dB/Okt.; 2000 Hz)
Nominal power handling with high pass
80 Watt(12 dB/Okt.; 2000 Hz)
Frequency- and impedance response
