SC 8 8 OHM
Magnetically shielded 8 cm (3.3") fullrange driver with cellulose cone and rubber surround. Very balanced frequency response. In conjunction with the shielded tweeter SC 5 8 Ohm especially suitable for small magnetically shielded 2-way combinations such as Surround center speakers and multi media systems.
Typical applications:
  • Surround centre speakers
  • Multimedia systems
  • Video monitoring screens
  • TVs
  • Computer terminals
No longer available.
Technical Data
Rated power
30 Watt
Maximum power
50 Watt
Nominal impedance Z
8 Ohm
Frequency response
70 - 15000 Hz
Mean sound pressure level
84 dB (1W/1m)
Excursion limit
6 mm
Resonance frequency fs
94 Hz
Magnetic induction
0.9 Tesla
Magnetic flux
170 µ Weber
Height of front pole-plate
3 mm
Voice coil diameter
2 cm
Height of winding
0.6 cm
Cutout diameter
7.3 cm
Net weight
0.25 kg
D.C. resistance Rdc
6.6 Ohm
Mechanical Q factor Qms
4.55
Electrical Q factor Qes
1.21
Total Q factor Qts
0.96
Equivalent volume Vas
1.7 l
Effective piston area Sd
32 cm2
Dynamically moved mass Mms
2.5 g
Force factor Bxl
2.8 T · m
Inductance of the voice coil L
0.6 mH
Frequency- and impedance response
Directivity pattern
Directivity pattern
Directivity pattern
Used in / Accessories:
