SL 70 - 4 Ohm
6.6 cm (2.6") full-range speaker with high efficiency and balanced and wide frequency response.
No longer available.
Typical applications
Narrow network column speakers
Monitoring speaker for electronic devices
Model construction
Electronic musical instruments
Technical Data
Rated power
8 W
Maximum power
15 W
Nominal impedance Z
4 Ohm
Frequency response
130–20000 Hz
Mean sound pressure level
87 dB (1 W/1 m)
Resonance frequency fs
220 Hz
Height of front pole-plate
2.5 mm
Voice coil diameter
15 mm
Height of winding
3 mm
Net weight
0.28 kg
Connections
2 x2.8 x 0.5 mm
Protective system
IP 65 *)
Temperature range
−40 ... 80 °C
Frequency- and impedance response
