TIW 360 8 OHM
Art. No. -
30 cm (12") High-End woofer with black cellulose cone, large magnet and heavy aluminium die-cast basket. Extremely high power handling due to 60 mm voice-coil, capton voice coil carrier, vented damper and magnet vent.
No longer available.
Technical Data
Rated power
300 Watt
Maximum power
600 Watt
Nominal impedance Z
8 Ohm
Frequency response
fu - 3000 Hz
(fu: Lower cut-off frequency depending on cabinet)
Mean sound pressure level
90 dB (1W/1m)
Excursion limit
24 mm
Resonance frequency fs
28 Hz
Magnetic induction
1.06 Tesla
Magnetic flux
2000 µ Weber
Height of front pole-plate
10 mm
Voice coil diameter
6 cm
Height of winding
2.5 cm
Cutout diameter
27.9 cm
Net weight
6 kg
D.C. resistance Rdc
5.8 Ohm
Mechanical Q factor Qms
4.11
Electrical Q factor Qes
0.31
Total Q factor Qts
0.28
Equivalent volume Vas
135 l
Effective piston area Sd
450 cm2
Dynamically moved mass Mms
70 g
Force factor Bxl
15 T · m
Inductance of the voice coil L
2.6 mH
Frequency- and impedance response
Directivity pattern
Directivity pattern
Directivity pattern
Waterfall spectrum
