TIW 360 X 8 OHM
Art. No. -
30 cm (12") High-End woofer with a particularly low resonance frequency. Double cellulose cone, large-scale magnet arrangement and a heavy die-cast aluminium basket. Excellent power-handling capabilities with minimum mechanical power loss due to the 60 mm voice coil mounted on a capton coil carrier, the pressure vented pole piece and the rear-vented damper. Particularly suitable for closed cabinets and transmission line applications.
No longer available.
Technical Data
Rated power
300 Watt
Maximum power
600 Watt
Nominal impedance Z
8 Ohm
Frequency response
fu - 4000 Hz
(fu: Lower cut-off frequency depending on cabinet)
Mean sound pressure level
86 dB (1W/1m)
Excursion limit
24 mm
Resonance frequency fs
21 Hz
Magnetic induction
1.06 Tesla
Magnetic flux
2000 µ Weber
Height of front pole-plate
10 mm
Voice coil diameter
6 cm
Height of winding
2.5 cm
Cutout diameter
27.9 cm
Net weight
6 kg
D.C. resistance Rdc
5.8 Ohm
Mechanical Q factor Qms
3.68
Electrical Q factor Qes
0.37
Total Q factor Qts
0.34
Equivalent volume Vas
140 l
Effective piston area Sd
450 cm2
Dynamically moved mass Mms
116 g
Force factor Bxl
15.89 T · m
Inductance of the voice coil L
2.6 mH
Frequency- and impedance response
Directivity pattern
Directivity pattern
Directivity pattern
Used in / Accessories:
