UL 12 100 V
2-band compact speaker with very modest dimensions but excellent sound reproduction, natural sound and linear frequency response across the entire response range. Maximum sound pressure is made possible by its robust and highly efficient construction. The drivers used are all magnetically shielded. Ideally suited to numerous flush-mounted or concealed applications due to the tidy, unobtrusive design.
Typical applications:
  • conference facilities
  • multimedia
No longer available.
Technical Data
Frequency response
95 - 20000 Hz
Mean sound pressure level
88 dB (1W/1m)
Opening angle (-6 dB)
120° x 120°
Net weight
4.1 kg
Transformer matching
40 Watt
Max. sound pressure level
100 dB (40W/1m)
Connections
Federklemme(spring-loaded terminals)
Befestigungspunkte
4 eingelassene Gewinde(4 sunken threaded holes)
Frequenzweiche
passiv. 12 dB/Okt.
Oberfläche
2-Komponenten Strukturlack(2-component textured paint)
Schutzgitter
Stahl. kunststoffbeschichtet(steel. plastic-coated)
Außenmaß Breite
180 mm
Außenmaß Höhe
271 mm
Außenmaß Tiefe
104 mm
Frequency- and impedance response
Directivity pattern
Directivity pattern
Directivity pattern
Directivity pattern
