UL 87 4 OHM
Art. No. -
Cabinet speaker, equipped with one 8.7 cm full-range loudspeaker. Black plastic housing. Remove the grille and loudspeaker to fit. The housing can then be fitted to a flat surface directly, without a holder. To this end, there are two screw holes in the base.
No longer available.
Technical Data
Rated power
10 W
Maximum power
15 W
Nominal impedance Z
4 OHM
Frequency response
150 - 10000 Hz
Mean sound pressure level
87 dB (1W/1m)
Net weight
0.33 kg
Sound pressure level
93 dB (1W/1m)@ 1865 Hz
Empfindlichkeit
89 dB (1W/1m)
Frequency- and impedance response
