UNI-SUB 30
Characteristics and sound properties
The UNI-SUB 30 employes two W 300 S - 8 Ohm on the push-pull principle. These are screwed back-to-back to the baffle and one woofer is assigned to each stereo channel. The results are worth listening to. The frequency graph shows the high level of efficiency and the almost ideal bandpass characteristics of this subwoofer. This is connected directly in parallel to the stereo speakers whose bass needs boosting. For this reason it is important that the impedance curve of the subwoofer does not too fall to too low levels as otherwise the booster might be overloaded. Nevertheless, one should be careful with low-impedance speakers and amplifiers without protective circuitry (very rare today) not to set the volume too high.
The tonality of this universal subwoofer can be described as precise and very dynamic and is particularly well suited to reproducing high output levels.
The high efficiency of the UNI-SUB 30 supports medium sized speakers in the bass and low bass range and this gives the music its live feel.
No longer available.
Component parts list for 1 box
Woofer
2 pcs.
Crossover
"Uni-Sub 30"
1 pc.
Terminal
2 pcs.
Damping material
Polyester wool
1 bag
Wood screws
4 x 20 mm
10 pcs.
Cable
2 x 2,5 mm²
3 m
Technical Data
Rated power
150 W
Maximum power
200 W
Nominal impedance Z
8 Ohm
Übertragungsbereich (-10 dB)
35 - 180 Hz
Mittlerer Schalldruckpegel
90 dB (1 W/1 m)
Trennfrequenz
150 Hz
Gehäuseprinzip
Net volume
50 l + 32 l
Außenmaß Höhe
567 mm
Außenmaß Breite
440 mm
Außenmaß Tiefe
440 mm
Frequency- and impedance response
