W 200 NG 4 OHM
20 cm (8") woofer with air-dried and reinforced cone. Very good price/performance ratio. Suitable for simple 2-way speakers and car rear tray systems.
No longer available.
Technical Data
Rated power
75 Watt
Maximum power
115 Watt
Nominal impedance Z
4 Ohm
Frequency response
fc - 4500 Hz
Mean sound pressure level
90 dB (1 W/1 m)
Excursion limit
18 mm
Resonance frequency fs
45 Hz
Magnetic induction
0.85 Tesla
Magnetic flux
530 µ Weber
Height of front pole-plate
6 mm
Voice coil diameter
3.3 cm
Height of winding
0.9 cm
Cutout diameter
18.4 cm
Net weight
1.18 kg
D.C. resistance Rdc
3.8 Ohm
Mechanical Q factor Qms
3.3
Electrical Q factor Qes
0.6
Total Q factor Qts
0.5
Equivalent volume Vas
50 l
Effective piston area Sd
213 cm2
Dynamically moved mass Mms
16 g
Force factor Bxl
5.3 T · m
Inductance of the voice coil L
0.6 mH
Sketch
Frequency- and impedance response
