WB 13 100 V/8 OHM (silver)
2-way compact speakers in a sturdy plastic housing (silver), fitted with one 13 cm woofer and one tweeter providing broad frequency response. Well suited for music and voices. Universally applicable to professional PA or in the home. Can be run as a 100 V system or as 8 ohm units due to an integrated transformer. 100 V transformer and 8 ohm mode are selected using a knob. Swivelling fixing bracket allows the speakers to be mounted horizontally or vertically, as required, and the housing is equipped with a threaded hole for attaching to a bracket or swivelling arm.
Typical applications:
  • Conference facilities
  • Multimedia
  • Outdoor useAttributes:
  • UV-resistant
  • 100 V transformer
  • Weather-proof plastic cabinet
  • Plastic: ABS (UL 94: HB)
No longer available.
Technical Data
Rated power
50 Watt
Maximum power
80 Watt
Frequency response
95 - 20000 Hz
Mean sound pressure level
88 dB (1W/1m)
Net weight
2.4 kg
Transformer matching
25 / 15 / 7.5 / 4 / 2 Watt / 8 Ohm
Sound pressure level
91 dB (1W/1m) @ 6108 Hz
Max. sound pressure level
102 dB (25W/1m)
Empfindlichkeit
90 dB (1W/1m)
Protective system
IP 54
Frequency- and impedance response
Directivity pattern
Directivity pattern
Directivity pattern
Directivity pattern
