WL 13 N AB - 100 V
Double wall speaker for PA installations with A/B wiring according to EN 60849. White wooden cabinet and metal grille. Fitted with two high quality full range speakers, two 100 V transformers and two fire-proof ceramic terminals with thermal fuse (fire damage at the speaker does not affect the function of the entire system). High efficiency, clear speech reproduction properties and good music reproduction. Removable rear panel for easy fitting to the wall using two screws. Connection to 100 V network and level trimming by means of ceramic terminals.
No longer available.
Typical applications
Wall-mounted speakers in 100 volt networks in public areas, schools, hotels, surgeries etc. for announcements and backgrounds For PA installations with A/B wiring according to EN 60849
Technical Data
Frequency response
120–16000 Hz
Mean sound pressure level
88 dB (1 W/1 m)
Opening angle (-6 dB)
18°/4000 Hz hor.70°/4000 Hz vert.
Net weight
1.68 kg
Transformer matching
2 x 3 W;2 x 1.5 W;2 x 0.75 W
Sound pressure level
94 dB (1 W/1 m)@ 1600 Hz
Max. sound pressure level
96 dB (6 W/1 m)
Colour
RAL 9010
Temperature range
–25 ... 70 °C
Frequency- and impedance response
Directivity pattern
Directivity pattern
