WL 13 NR P - 100 V
Wall-mounted speaker with a volume control-knob and priority relay, wooden cabinet and metal grille. Fitted with a high quality full range driver. Removable rear panel for easy fitting to the wall using two screws. Good music reproduction and clear speech reproduction properties. Connection to 100 V network and level trimming by means of spring terminal.
Also available:
No longer available.
Typical applications
Wall-mounted speakers in 100 volt networks in public areas, schools, hotels, surgeries etc. for announcements and backgrounds
Technical Data
Frequency response
90–20000 Hz
Mean sound pressure level
88 dB (1 W/1 m)
Opening angle (-6 dB)
79°/4000 Hz hor.61°/4000 Hz vert.
Net weight
1.4 kg
Transformer matching
6; 3; 1.5 W
Sound pressure level
96 dB (1 W/1 m)@ 4954 Hz
Max. sound pressure level
96 dB (1 W/1 m)
Colour
RAL 9010
Temperature range
–25 ... 70 °C
Frequency- and impedance response
Directivity pattern
Directivity pattern
