WL 13 PR P - 100 V
Wall-mounted speaker with a volume control-knob and priority relay, white plastic cabinet and metal grille. Fitted with a full range driver. Good music reproduction and clear speech reproduction properties. Connection to 100 volt network and level trimming by means of spring terminal.
Also available:
No longer available.
Typical applications
Wall-mounted speakers in 100 volt networks in public areas, schools, hotels, surgeries etc. for announcements and backgrounds
Technical Data
Frequency response
90–16000 Hz
Mean sound pressure level
88 dB (1 W/1 m)
Opening angle (-6 dB)
74°/4000 Hz hor.67°/4000 Hz vert.
Net weight
1.15 kg
Transformer matching
6; 3; 1.5 W
Sound pressure level
94 dB (1 W/1 m)@ 5312 Hz
Max. sound pressure level
96 dB (6 W/1 m)
Empfindlichkeit
90 dB (1 W/1 m);700 - 7000 Hz)
Temperature range
0 ... 70 °C
Frequency- and impedance response
Directivity pattern
Directivity pattern
