WSP 26 S 8 OHM
25 cm (10") HiFi woofer with highly damped, nawi-shaped polypropylene cone. High power handling due to capton voice-coil carrier and magnet vent.
No longer available.
Technical Data
Rated power
110 Watt
Maximum power
140 Watt
Nominal impedance Z
8 Ohm
Frequency response
fc - 7000 Hz
Mean sound pressure level
91 dB (1 W/1 m)
Excursion limit
22 mm
Resonance frequency fs
19 Hz
Magnetic induction
1 Tesla
Magnetic flux
1250 µ Weber
Height of front pole-plate
8 mm
Voice coil diameter
5 cm
Height of winding
1.45 cm
Cutout diameter
23.3 cm
Net weight
2.5 kg
D.C. resistance Rdc
5.7 Ohm
Mechanical Q factor Qms
3.19
Electrical Q factor Qes
0.38
Total Q factor Qts
0.34
Equivalent volume Vas
230 l
Effective piston area Sd
330 cm2
Dynamically moved mass Mms
42 g
Force factor Bxl
8.7 T · m
Inductance of the voice coil L
1.2 mH
Frequency- and impedance response
