Alt 23.05.2012, 17:32   #1
brkl
English help with a Boxsim project?
Hi! I've been designing a speaker with Boxsim and I need someone who knows more about loudspeaker to look at the project and check out what problems it might have. I figured this is the best place to ask, except I don't speak German! I haven't designed a speaker before and I don't really know all that much about all the different mistakes I can make.
The project is to make 3-way loudspeakers out of two cabinets of an old desk. I don't have the actual desktop, only cabinets. They look nice, so I think the best way to make use of the cabinets is to turn them into loudspeakers!
I chose the drivers and made the crossover (I know very little about crossovers) in order to straighten out the frequency response. However, I don't know if I caused some other problems. If anyone could take a look at the project file and offer some comments (in English), they would be much appreciated!
Dateityp: bpj 3way w250s sc10n dtw72.bpj (55,9 KB, 45x aufgerufen)
brkl ist offline   Mit Zitat antworten
Alt 23.05.2012, 17:58   #2
walwal
Welcome.
Your crossover is ok, but this one should work a little better. Not so harsh anl less Resonances from the Sc 10. Also the tweeter has a steeper "Shoulder" and Phase fits better. The resistor 3 Ohm in the midsection has to be evaluated by your ears and in your room.
Good luck.
Dateityp: bpj 3way w250s sc10n dtw72 wal.BPJ (56,0 KB, 34x aufgerufen)
__________________
Jürgen
walwal ist gerade online   Mit Zitat antworten
Alt 23.05.2012, 18:05   #3
Chaomaniac
The SC 10 N will not work well at frequencies far below 3 kHz.
Why do you want to use 2 different tweeters?
__________________
Welcome to Visaton-church!
Breiter Sweetspot gefällig? — Mono heißt die Lösung!
Aus Fehlern wird man klug, drum ist einer nicht genug!
dass vs. das
seit vs. seid
Chaomaniac ist offline   Mit Zitat antworten
Alt 23.05.2012, 18:19   #4
brkl
Ah, I suppose I should have known that. The frequency response simply seemed flat where I needed to bridge the gap between the tweeter and bass. Also, it was cheap I'll have to look at some other driver. Thanks
Also, thanks for taking a look at the crossover, walwal! I'll compare them and study what you changed.
Alt 23.05.2012, 20:08   #5
walwal
Chao is right, i think. i had a blackout. Take the Al 130 (not cheap, but very fine) and you will be satisfied.
__________________
Jürgen
Alt 24.05.2012, 10:53   #6
zxlimited
Hello brkl,
here´s my proposal for your speaker. Take the W 130 S as midrange. It is way cheaper than the AL 130 but still a very good midrange driver.
I optimized your simulation in order to obtain a very flat frequency response and good phasing. You can check for correct phasing very easily: Just reverse the polarity of one driver. You should see a deep dip in the overall frequency response where the two drivers cross. If the dip is not very deep, it is not optimal. If you have no dip at all or even at some points the overall SPL in the transition region is higher than the SPL of a single driver, you´ve done something terribly wrong
Please note that, as the W 130 S is a cone driver which is open at it´s rearside, you need an extra housing for it. You cannot put it in the same housing with the W 250 S! Just build a little wooden box or take a flower pot or something and glue it behind the hole of the W 130 S from the inside of your cabinet. The volume should be around 3 Liters, according to my simulation.
Best regards, Martin
Dateityp: bpj 3way w250s sc10n dtw72-1_Martin.BPJ (56,3 KB, 40x aufgerufen)
__________________
Entwicklungsingenieur für Home-HiFi und Car-HiFi
zxlimited ist offline   Mit Zitat antworten
Alt 24.05.2012, 11:00   #7
zxlimited
Ah, almost forgotten: Does anybody of you also have a wrong/incomplete dataset of the DTW 72? When I load it, it has many values = 0 . That´s why it doesn´t give you a result for max SPL for example. As I didn´t thoroughly check what else might be wrong, I took the DT 94 instead.
__________________
Alt 24.05.2012, 11:47   #8
jama
I would have a light modification in martin's simu...
The sound will so be warmer and English...
Miniaturansicht angehängter Grafiken
Klicken Sie auf die Grafik für eine größere Ansicht
Hits:	69
Größe:	98,5 KB
ID:	14779   Klicken Sie auf die Grafik für eine größere Ansicht
Hits:	58
Größe:	32,3 KB
Dateityp: bpj 3way w250s sc10n dtw72-1_Martin 2.BPJ (56,4 KB, 31x aufgerufen)
__________________
jama ist offline   Mit Zitat antworten
Alt 24.05.2012, 12:15   #9
GabbaGandalf
OT
@zxlimited: Yes, the DTW 72 Data seems to be incomplete in my Boxsim too.
To use this driver i just assume Pmax=5W and xmax =0.1mm.
__________________
GabbaGandalf ist offline   Mit Zitat antworten
Alt 24.05.2012, 15:12   #10
brkl
You really are a helpful bunch!
Yes, I think W130S would suit this project better than AL130. Simply because of cost. Thank you very much for taking the time to edit the project!
I don't like that dip in the highest frequencies that DT 94 has, but I suppose beggars can't be choosers. I can probably live with it. Very strange about the missing data of the DTW 72, good thing I didn't just start building!
Jama, is your modification just to change the impendance, or both the impedance and the frequency response? I'd prefer neutral to warm sound. I suppose low impedance would mean that I would have to be careful in regard to what amplifier I use.
There was a nasty dip in frequency response at the W 130 S - DT 94 crossover frequency around 30 degrees towards the top. Since the speakers are quite low, this could be a problem. I switched the places of the tweeter and midrange drivers, which made the dip happen 30 degrees towards the floor -- which is not a problem Any comments about this? Most speakers I see have the tweeter higher than the midrange.
Thanks again for your help
Alt 24.05.2012, 16:33   #11
jama
@brkl
Can you see the images?
The additional capacitor (22 micro) acts only lies between 200 and 700 hertz...
In dotted line without her.
__________________
Alt 24.05.2012, 20:44   #12
Peter K
Hallo Martin,
sorry, but I think this statement
Zitat:
If you have no dip at all ........you´ve done something terribly wrong
is not correct...
If this happens, you have designed a perfect third Order acoustical Butterworth-Filter.
As far as I am informed , there is nothing wrong about an ideal third Order Butterworth.....
best regards
Peter Krips
Peter K ist gerade online   Mit Zitat antworten
Alt 24.05.2012, 21:54   #13
brkl
Zitat:
@brkl
Ah, sorry, I simply got confused because the scale changed.
Antwort
Themen-Optionen Thema durchsuchen
Thema durchsuchen:
Erweiterte Suche
Forumregeln
Es ist Ihnen nicht erlaubt, neue Themen zu verfassen.
Es ist Ihnen nicht erlaubt, auf Beiträge zu antworten.
Es ist Ihnen nicht erlaubt, Anhänge hochzuladen.
Es ist Ihnen nicht erlaubt, Ihre Beiträge zu bearbeiten.
BB-Code ist an.
Smileys sind an.
[IMG] Code ist an.
HTML-Code ist aus.
Gehe zu
Alle Zeitangaben in WEZ +2. Es ist jetzt 15:02 Uhr.
Powered by vBulletin® Version 3.8.7 (Deutsch)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
