CT MAIN 200
Building instruction
Exploded drawing
Assembly
The cabinet consists of 19 mm boards and a 16 mm double baffle. The side piece, top and base of the medium range chamber are, at the same time, cabinet stiffeners. First of all, make the necessary cut-outs in the cabinet panels and the chamfers on the double baffle. Once the cabinethas been made up, prepare the mounts for the woofer and the mid-range drivers. Finally, fit the speaker drivers. If required, a stand can be made using the same size as the cabinet base to the required height.
Inner damping
The damping of the speaker uses half a mat of damping material pushed into the medium range cabinet. The remainder is pushed into the bass chamber.
