ALTO LINE
Characteristics and sound properties
The ALTO LINE is a slim, 2-band column speaker with two 13 cm mid-bass units and one dome tweeter.
Due to its slim design and the correspondingly small footprint, this model is ideal as a free-standing speaker in smaller rooms.
The spatial separation is well handled by the speakers and can, as a result, produce clear sound characteristics even in "normal" living rooms.
The unusually broad range bass spectrum for a speaker of this size, that remains crisp even at higher output levels, is a point worthy of note.
As a result of its balanced, crisp sound characteristics, and the finely detailed, exuberant high-frequency output, the ALTO LINE can be considered a fully-fledged member of the ALTO speaker family.
- no longer available -
Rated power | 80 W |
Maximum power | 130 W |
Nominal impedance Z | 4 Ohm |
Übertragungsbereich (-10 dB) | 33 - 22000 Hz |
Mittlerer Schalldruckpegel | 83 dB (1 W/1 m) |
Trennfrequenz | 3000 Hz |
Gehäuseprinzip | Bassreflex |
Net volume | 30 l |
Außenmaß Höhe | 900 mm |
Außenmaß Breite | 190 mm |
Außenmaß Tiefe | 270 mm |
