VOX 251 HE-DIPOL
Characteristics and sound properties
The new VOX 251 HE-DIPOL loudspeaker is based on the VOX 251 HEmain loudspeaker and combines its excellent sound reproduction capabilities with the unique diffused sound reproduction of a dipole system. This effect speaker covers the entire frequency range and can deal effortlessly with the highest volume settings and the lowest frequency bass sounds. Doubling up the mid- to high-range unit and using the phase-inverted system at the rear of the cabinet in conjunction with the side-mounted TIW 250 8 Ohm woofer leads to the required diffused sound field with unbelievably dynamic bass reproduction. The VOX 251 HE-DIPOL was specifically designed for combining with the VOX 251 HE main loudspeakers and the VOX 251 HE-CENTER. Here, too, the principle of the bass tunnel construction was employed making full-range operation a "must" for this effect speaker. The VOX 251 HE-DIPOL is positioned to the side of the listening position with the woofer facing the ear, in order to attain the optimum listening effect. This Dipole is ideally suited to building up a multi-channel system based on the VOX 251 HE, that will guarantee you a film experience second to none.
This new version contains the new tweeter G 25 HE 8 Ohm.
No longer available.
Component parts list for 1 box
Tweeter
G 25 HE 8 Ohm
2 pieces
Midrange driver:
AL 130 8 Ohm
4 pieces
Woofer:
1 piece
Crossover:
Terminal
1 piece
Damping material:
4,5 bags
Special wood screws:
5 x 30 mm
4 pieces
Wood screws:
3.5 x 19 mm
16 piece
Countersunk screws:
3.5 x 25 mm
12 pieces
Material for speaker covers:
width 50 cm
0.5 m
Cable
2 x 2.5 mm2
3 m
2 x 1.5 mm2
4 m
Technical Data
Rated power
200 W
Maximum power
350 W
Nominal impedance Z
4 Ohm
Übertragungsbereich (-10 dB)
28 - 25000 Hz
Mittlerer Schalldruckpegel
84 dB (1 W/1 m) Trennfrequenz
Trennfrequenz
200 / 3000 Hz
Gehäuseprinzip
Net volume
76 l + 4 l + 4 l
Außenmaß Höhe
1150 mm
Außenmaß Breite
465 mm
Außenmaß Tiefe
235 mm
